impossible to snap
How it should work: This variable turns on/off pipe support osnaps. Similar to DGNOSNAP. When On - each snap point works as usual. You can snap for pipe inline asset like for any other object. When off - only Endpoint & Midpoint snap point is available as it is now in Plant 3D.
Why it is important: Currently snap points (excluding Endpoint & Midpoint) are hardcoded deactivated. That means measuring distance, moving to/from certain point is very limited. For example: moving pipe from flange to keep accurate, minimum distance from pipe wall to flange is really hard. It's user unfriendly. But when implemented piping design would be back on track.
Example: Measure perpendicular distance from weld neck flange to pipe wall. Impossible... See picture below for details.
impossible to measure
