I`m struggling with a loose flange joint.
I am using a welding ring with collar (EN 1092-1 type 35) and loose plate flange (EN 1092-1 type 02).
The connection looks like this (Plant 3D) and I`m trying to get it look like a Mechanical 2D.
I think that is how it should look a like. The face of collar is like "inside" of the loose flange.
Is there a way to fix this?
Plant 3D
Mechanical 2D
Dear @Anonymous ,
unfortunately, I can not adjust your problem in Plant 3D 2020.
please look at the configuration of the Spec 25HS01 which looks like this:
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
It is possible to get loose flanges with collars position correctly in Plant. The problem is most likely that you don't have the 'Flange Offset' property set on your collar components in your spec.
Collared connection in plant with 'flange offset' property set for collars:
