AutoCAD Plant 3D Forum
Wiew of loose flange connection
2 REPLIES 2
511 Views, 2 Replies
I`m struggling with a loose flange joint.
I am using a welding ring with collar (EN 1092-1 type 35) and loose plate flange (EN 1092-1 type 02).
The connection looks like  this (Plant 3D) and I`m trying to get it look like a Mechanical 2D.
I think that is how it should look a like.  The face of collar is like "inside" of the loose flange.
Is there a way to fix this?
Plant 3DPlant 3D
Mechanical 2DMechanical 2D
2 REPLIES 2
h_eger
Dear @Anonymous ,
unfortunately, I can not adjust your problem in Plant 3D 2020.
please look at the configuration of the Spec 25HS01 which looks like this:
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
matti_laakko_12345
It is possible to get loose flanges with collars position correctly in Plant. The problem is most likely that you don't have the 'Flange Offset' property set on your collar components in your spec.
Collared connection in plant with 'flange offset' property set for collars:
Technology Administrators
