Why does this happen?
johan.degreef
Advisor Advisor
johan.degreef
Dear, When stretching a line with some valves on it it gets messy, why?
Do we have drawing methods that are not ok?
Many Thanks
video:
https://photos.app.goo.gl/ysGR45dvcE6MqvS69
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
h_eger
@johan.degreef ,
this behaviour has been known since AutoCAD Plant 3D P&ID 2010 and there will be no solution for it.
The only workaround I use is to make the changes in small steps and, if necessary, detach the measuring points from the SLine.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
MarkusRufflar
because you a trying to stretch blocks. use move command and or the grips on the segments. isntead of stretching something
