Weld dot size IN MODEL too small
rguarinoSXCXN
rguarinoSXCXN
Hi, does anyone know how to make the weld dot size IN THE MODEL to be larger?
One project im working in the weld size is larger and the other project im working in its very small. Both projects are set up the same.
See pics below
Both project settings the same
This project they are small
This project they are larger and easier to see
DVaquand
Hello @rguarinoSXCXN
Does the REGEN command update the size of the welds?
== French ==
La commande REGEN cela met-elle à jour la taille des soudures ?
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
h_eger
@rguarinoSXCXN ,
here you can adjust the size of the welding symbol. After making a change, execute the REGEN3 command or save and close the models. The welding symbols will be displayed in the desired size the next time you open the P3D model.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
rguarinoSXCXN
I made sure .25 is in both projects and both projects have different weld sizes. This is after I do REGEN.
rguarinoSXCXN
It does not
lauri_barnhart
Hello @rguarinoSXCXN, thanks for posting in the community!
Just checking in - has your issue been resolved?
If you've found a solution, please share it here so other users benefit from the information.
If not, please provide an update so other members can jump in with further suggestions.
Best,
Lauri | Community Manager
