AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Valve direction on Isometrics without using an Actuator
4 REPLIES 4
jovan.maharaj
175 Views, 4 Replies
Hi
I would like to know if it is possible to show the direction of a valve on an isometric, without setting up an actuator in spec editor for that valve?
Thank you 🙂
4 REPLIES 4
h_eger
in reply to: jovan.maharaj
@jovan.maharaj ,
No
The valve actuator alignment on the Iso only works if the valve body and actuator are set up in the catalogue and the Spec and are inserted in the 3D model.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jovan.maharaj
in reply to: h_eger
What do you think would be a work around to that problem, if you are using custom scripts that generate the valve body with an actuator? @h_eger
h_eger
@jovan.maharaj ,
one solution is to create the Python script as ValveBode in the catalogue.
Then create a parametric actuator in the catalogue (it does not have to be very large) which is located within the Python script and then assign it in the catalogue.
So I don't see the parametric actuator in the 3D model but the correct orientation of the valves appears on the isometry.
Hartmut Eger
Senior Engineer
XING | LinkedIn
jovan.maharaj
in reply to: h_eger
I shall try this, thank you!!!
