AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
UPDATE MANY ORTHO DRAWINGS IN ONE CLICK
4 REPLIES 4
737 Views, 4 Replies
Hello everyone!!! Is't possible to update many files with ortho drawings in one click?  Or I have to open each file and click update views?
I'm notice that  AutoCAD Plant 3d  began keep layer state for orthodrawings  - it's nice!  But how we can update many files?
4 REPLIES 4
h_eger
Hi @Anonymous,
yes it's possible.
Change to the Orthographic DWG tab in the Project Manager.
Check all Ortho Drawings and right click and "Update Views"
This process can take several minutes, depending on the PC configuration 🙂
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
Thank you! But if I do like this it will update only in one file! I try it many times.  I try to at first open all, select all files and than update it - the result only in one file. And I try to close all files - and than selaect all files click update views - the result the same - only in one file! I use Plant 2017.
dave.wolfe
We have a plugin that allows you to select and update multiple files:
http://www.pdoteam.com/store/fasttrack-plant/
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
in reply to: dave.wolfe
O!!! Thank you! Now I now and I'm sure  that this function is't available in Plant 3D)))
This functioin is  incredible, miracale  and nice!) I hope Autodesk will attach it to Plant 3d, so native function like update all files)
I hope see it in Plant 3D)
I hope see it in Plant 3D 2023)
Technology Administrators
AutoCAD Beta
