Hello everyone!!! Is't possible to update many files with ortho drawings in one click? Or I have to open each file and click update views?
I'm notice that AutoCAD Plant 3d began keep layer state for orthodrawings - it's nice! But how we can update many files?
Hi @Anonymous,
yes it's possible.
Change to the Orthographic DWG tab in the Project Manager.
Check all Ortho Drawings and right click and "Update Views"
This process can take several minutes, depending on the PC configuration 🙂
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Thank you! But if I do like this it will update only in one file! I try it many times. I try to at first open all, select all files and than update it - the result only in one file. And I try to close all files - and than selaect all files click update views - the result the same - only in one file! I use Plant 2017.
We have a plugin that allows you to select and update multiple files:
O!!! Thank you! Now I now and I'm sure that this function is't available in Plant 3D)))
This functioin is incredible, miracale and nice!) I hope Autodesk will attach it to Plant 3d, so native function like update all files)
I hope see it in Plant 3D)
I hope see it in Plant 3D 2023)
