unhandled exception has occurred in a component in your application
Message 1 of 11
I am a Autoplant 3D user and when I open project setup and trying to modify the isometric template then below error message pop-up.
any suggestions please.
Replies (10)
Message 2 of 11
Dan.Scales
Hi @Anonymous,
Does the same issue occur when you attempt to edit the template in one of the standard iso styles?
Dan
Dan Scales
Message 3 of 11
jabowabo
Your title block must be named "Title Block"
Message 4 of 11
Dear Dan,
Yes, same issue occur while edit/modify the standard iso styles.
please find below the snapshot for your reference.
Vaibhav
Message 5 of 11
still error occur
Message 6 of 11
waiting for solution sir...
Message 7 of 11
Message 8 of 11
Try purging your iso.dwt and restarting Plant.
Message 9 of 11
issue not resolved.
Message 10 of 11
What is the name of your dwt file?
Message 11 of 11
Dan.Scales
Hi @Anonymous,
Unfortunately I think you are going to need to switch to a previous "good" backup copy of the project:
Error-Object-reference-not-set-to-an-instance-of-an-object-when-clicking-Setup-title-block-in-AutoCAD-Plant-3D
Dan
Dan Scales
