Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD Plant 3D Forum
UCS reverting to WCS when piping
35 REPLIES 35
Message 1 of 36
5153 Views, 35 Replies
This seems to be a fairly documented problem, but with no real solution?
When working with a custom UCS, plant decides to place fittings alligned to WCS.
So, a tee/elbow will send the piping model off on the wrong co-ordinates.
This is a huge problem and shifting the model back to WCS is not an option as there are other disciplines working on the model, using different software platforms.
I have scrolled through the relative posts and tried all suggested fixes, but had no success.
Toggling the DYNAMIC UCS settings had no affect.
Surely this has been addressed? We are running 2015 on SP2.
Hopefully someone can help?
35 REPLIES 35
Message 21 of 36
in reply to: PeterQuinn
Hello Peter,
I am also having the same issue with the UCS reverting to world when routing pipe.
I have the latest SP installed but still have the same issue.
Unfortunately I cannot upload a screencast, but a basic rundown of the steps to reproduce;
  1. Route pipe in plan on single plane, works as expected.
  2. I change elevation, using 3D view, then try to route from new elevation.Routing now reverts to using World UCS.
Hopefully the image appears correctly below, showing the issue.
Message 22 of 36
JamieZwicker
I have the same issue.  I've tried most of the posted solutions (i've tried every setting in the UCSMAN widow).  Any help from AutoDESK here?
Message 23 of 36
3 years later and this is still a problem! Why is it that Autodesk can't fix simple issues like this that really make our jobs difficult?
We can't have the UCS flipping around on us when we're trying to route pipe. It's documented and you're aware of the problem but nothing gets fixed year after year. Very disappointing...
Message 24 of 36
JamieZwicker
I have come up with a very tentative, annoying, but practical solution.  Say you're in plan view and your UCS works fine.  Then when you click in a different view (FRONT, LEFT, ETC), the UCS sometimes switches to World (that's why we're all reading this forum).  You'll know when this happens because you can't model pipe correctly and the UCS logo turns light grey.
As a solution try typing UCS enter then V enter.  Annoying, but it works.
Jamie Zwicker
Message 25 of 36
Slawomir_
AutoCAD Plant 3D 2020.1 Update built on AutoCAD 2020.1.3 have the same issue.
Tags (1)
Message 26 of 36
5 years on and no solution. . . does autodesk even care?
Message 27 of 36
dave.wolfe
I've tested this on 2019 just now, and the original problem that was reported has been fixed.  I'm not able to duplicate the more recent workflows. If you can duplicate it, can you list steps that can be tested?
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 28 of 36
in reply to: dave.wolfe
I have attached a screen capture video that shows the problem.
Message 29 of 36
dave.wolfe
Thanks for the video. That helps a lot. I've been able to reproduce this on 2022 as well, so I've got a case in. I'd love to be able to see this thread closed with a fix, I'll make a note to follow back up at the next service pack or hotfix release and post an update.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 30 of 36
Nole.DelaCalzada
Plant 3D 2021 still has this issue. Subscribing to this thread for a possible solution.
Message 31 of 36
in reply to: Nole.DelaCalzada
don't hold your breath.
Message 32 of 36
olivem2XGML
any fix yet? using 2020
Message 33 of 36
Was this patched? I have a large effort coming up that will require custom building coordinate systems to differ from the master plant coordinate system and all the scan data available.
CASEY O'CONNOR
CAD Administrator / Senior Mechanical Designer
ProgressiveDesign®
5309 Commonwealth Centre Parkway
Suite 300
Midlothian, Virginia 23112
Office: (804) 330-8055 ex) 1179
Cell: (304) 546 0566
www.progressive-design.com
Message 34 of 36
CASEY O'CONNOR
ProgressiveDesign®
Suite 300
Message 35 of 36
Hi, i found the solution on this.
The problem is that UCSFOLLOW is turned on(1). Turn it off(0) and it should work.
Message 36 of 36
softwareA75QQ
mate its 2023 and no solution to this
