Tri-Clamp Valve Catalog?
I have a project that is using all 304 OD tube with Tri-Clamp connections. I have the fittings and piping in the spec but I can not find TC valves anywhere. Does anyone know where the is a full Tri-Clamp valve catalog that I can download, even if it requires a purchase? I need hand valves,control valves, check valves, ect. Please let me know what is out there as I do not have the time to try to build a complete custom catalog.
Thank you
h_eger
Dear @Anonymous,
you can swoop on Apps Autodesk.
there is nothing there you have to create the Valves yourself.
https://apps.autodesk.com/PLNT3D/de/List/Search?facet=__category%3a%3aCatalogs+%26+Specs
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dan.Scales
Hi @Anonymous,
As @h_eger says, you can download various content from the App Store.
The following forum thread lists the catalogs that are available:
https://forums.autodesk.com/t5/autocad-plant-3d-forum/available-plant-content-packs-in-autodesk-exchange/td-p/6652646
Dan
Dan Scales
