Transfer P&ID information to P3D with P&ID Object Mapping
mario_biasi_athenagroupsrl
Hello everyone,
We have configured the P&ID object mapping, as we need to transfer P&ID information to the P3D object model parameters.
As a result, some information is correctly transferred from P&ID to P3D when we insert a 3D component via the "P&ID Line List" interface.
However, the piping "Service", "Insulate Type", and some other property values ​​are not being transferred from P&ID to P3D.
What could be the issue?
ben.saa
Autodesk Support
Autodesk Support
Custom Property Mapping Limitations:
- In AutoCAD Plant 3D 2024, custom properties created in the 3D catalog or specification and P&ID class definitions may not appear in the mapping table. Upgrading to AutoCAD Plant 3D 2026 or newer versions
obulesub
Hi @mario_biasi_athenagroupsrl ,
Just checking in to see if you were able to make any progress with the suggestions shared by the community. If you're still experiencing the issue, please feel free to provide additional details about your setup and the properties involved so the community can continue investigating.
Thanks!
Obulesu | Community Manager
@ben.saa
thankyou for your email.
Actually I'm using the 2027.1 version, and I've this problem.
Any suggest?
