Im trying to create a new piece of equipment. Clicking on the button (_PLANTEQUIPMENTCREATE) I get the message in the comand line
"The nozzle catalog could not be found at \NOZZLE Catalog.acat"
I have the "Nozzle Catalog.acat" in "C:\AutoCAD Plant 3D 2015 Content\CPak Common" and in "C:\AutoCAD Plant 3D 2015 Content\Migrated Content 4_0"
whats wrong? how do i get AutoCAD to find them there?
Solved by patpat79. Go to Solution.
How many users are doing your project?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Try using the command "PLANTMODIFYSHAREDCONTENTFOLDER" so you could check if your content folder's location is correct or your nozzle catalog's location is "really" correct.
Best Regards,
Pat Andres
GHD Manila
The specified location was correct, but the file "ContentConfig.xml" wasnt there. I copied it over from my 2013 release and all is working now.
Thanks patpat79
Hi
I'm experiencing the same problem, the ContentConfig.xml is missing. I'm using Autocad Plant 3D 2019 and can't locate the file anywhere. Where can I get it?
Thanks in advance
