Converting CADWorx spec to Plant 3D, datafile.tbl file
abotkin
abotkin
We are trying to convert a batch of specs from CADWorx over to Plant 3D but do not have the required datafile.tbl file to be able to do so. Is something that needs to be created first in CADWorx before we try the conversion, and if so how? Any help or advice would be greatly appreciated.
lfitzhenry
If I remember correctly, CADWorx specs created after 2013 are not able to be converted to P3D.
abotkin
Thank you for the response, I fear that this is the case as well
