I have a problem with Report Creation only for projects with SQL Expess. With other projects everything is good.
We have the same error with SQL.
There is no dialog to log in.
The Report Create will work with Windows Authentication for SQL Express. With SQL Authentication there is some issue opening project data and we are currently looking at it. Expect something soon on this.
Thanks for the heads up. We've confirmed that this is an issue and are working on it. As usual, I can't give any details on when it will be addressed.
marina.yurova escribió:Hello,
Report Creator ne rabotaet v proektax kotorie podkreplenni s SQL serverom, tak kak SQL server imeet svoi sobstvennie vozmojnosti dlya formirovaniya dokladov, na primer Report Builder.
If anybody has the same problem and wants to use Report Creater with Project with SQL Express, there is one trick.
In the project folder there is 4 files
iso.dcf
otho.dcf
Piping.dcf
ProcessPrower.dcf
Then in every file after the Integrated Seguruty paste the following
<Name>Integrated Security</Name>
<Value xsi:type="xsd:boolean">false</Value>
</Parameter>
<Parameter>
<Name>user id</Name>
<Value xsi:type="xsd:string">sa</Value>
</Parameter>
<Parameter>
<Name>Password</Name>
<Value xsi:type="xsd:string">as</Value>
</Parameter>
<Parameter>
sa - is the id name
and as is the password
After that everything works good.
May be there is a way how to avoid this operation?
Thank you very much
Thanks for this solution.
It's a solution which Autodesk unfortunately didn't provide. 😞 :(
Best regards,
Gerald
The solution it is in the Service Pack 1 for Plant3D 2012:
"Report Creator
Corrected a problem that prevented Report Creator from opening projects that require SQL authentication"
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18430575&linkID=14116968
