AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
What Super Computer (Questions for AutoCAD base product developers)
16 REPLIES 16
Message 1 of 17
abilioramos
3449 Views, 16 Replies
I have spend at least 3 months building a power plant. After the project finished we have send all DWG to our costumer.
This company works with AVEVA PDMS. They have recreated all our project in 95% of the layout and add some modifications and improvements to it.
Now here is the deal I have visited this company, I have seen this project running in AVEVA PDMS that is installed in one computer that is inferior 60% comparing the one I use with Autodesk Plant 3D. And MY GOD it is super FAST in shaded mode, any thing you do like Zoom, 3D orbit, Pan, Wheel zoom etc. it is incredible fast, it is instantaneous.
It was not 5 minutes test, they had taught me how to use PDMS to look around (Zoom, 3D orbit, Pan, Wheel zoom) I have used this software during 5 days to walk true the plant in the computer to find some solutions for some problems, and it is fast, the computer have a graphic card Geforce 8600 GT and the resources used by this software are extremely low (I will try to get this compter full configuration to post here). This was full PDMS 12.0SP5 version not just a viewer like Navisworks.
In AutoCAD base products, at least the ones I work with AutoCAD + AutoCAD Plant 3D, we have graphic cards that ware prepared for CAD software, at this moment my computer have one NVIDIA Quadro FX 1800.
Comparing AutoCAD Plant 3D with PDMS, each time I do one Zoom, 3D orbit, Pan, Wheel zoom some times it takes 10 seconds or more to finish the command, and 70% of the time the shade render is not correct you can see all the lines like it is in wire mode but with shade, and some times just crash. I’m not talking about AutoCAD Plant 3D only that is a Beta product, but also AutoCAD 2009 that is the last licensed Autocad that we have. It is impossible to walk around when you starting to have your project fill of equipments, pipes, buildings etc.
Sorry to say, but is impossible to compete with other companies, if they can produce faster than you. I’m a long time AutoCAD user for 15 years now and each time Autodesk releases one new AutoCAD is getting slower and slower to work with and more resources consumption.
My questions are:
Aren’t NVIDIA, Microsoft, Autodesk partners?
Don’t all work together to make better and faster products?
Why Autodesk products are getting slower in each version release, shouldn’t be the other way around?
Don’t you think its time to rewrite the graphic card code to improve it?
What kind of NASA super computer we need to buy to work Autocad based products?
Do we need to find other software solutions to stay in the market?
Here is my current computer configuration (It is fully updated drivers, windows etc), I think it is a super computer considering the one I have worked with PDMS 12.
Operating System: MS Windows XP 64-bit SP2
CPU: Intel Core i7 860 @ 2.80GHz
RAM: 8.0GB Dual-Channel DDR3 @ 668MHz 9-9-9-24
Motherboard: ASUSTeK Computer INC. P7P55D PRO (LGA1156)
Graphics: Plug and Play Monitor on NVIDIA Quadro FX 1800
Hard Drives: 640GB Western Digital WDC WD6400AADS-00M2B0 (IDE)
Optical Drives: ASUS DRW-24B1ST
Audio: VIA High Definition Audio
Best Regards,
Abilio Ramos
16 REPLIES 16
Message 2 of 17
in reply to: abilioramos
100% agree with you.
Message 3 of 17
An AutoCAD so slow is not acceptable.
Message 4 of 17
abilioramos
First let me start by saying that is not my intention to talk bad about AutoCAD based products.My intention is to remember Autodesk what it seems to be a taboo.
I have notice that this AutoCAD performance is a long time issue, and I don´t see or read any where Autodesk doing something to solve it. Probably no one from Autodesk will post on this message. Why? I don't know maybe they don't have authorization to talk about it, or the solution is to expensive for Autodesk.
The main focus of Autodesk has become to release one new version of Autodesk based products each year, it doesn't matter the performance, if it works with minimum system requirements its ok for release. Them you wait 5 minutes for AutoCAD to start on your minimum system requirement computer. Why all software developers don't post in there website the Ultimate System Requirement instead of Minimum System Requirement?
I have contacted our Autodesk reseller, to help us to find a better hardware solution, and I can guarantee that they understand less them me. I think must of them don't know what AutoCAD is and what it does. In my country Autodesk help su..ks, if you have a problem they don't know the solution or it will be fixed in the next release. Nice help!!
Autodesk makes millions of euros/dollars each year with new licenses and subscription programs, and I sincerely hoop Autodesk keeps selling AutoCAD for long and long years.
Has I told before I'm a long time AutoCAD user, and I really love to work with it, except for this lack of performance and the famous fatal errors. I plan to keep using AutoCAD or AutoCAD based products until my retirement 🙂
Question for all of you, which will be the super computer to work with Autodesk AutoCAD Plant 3D? I talking to build a big petrol refinery.
Edited by: abilioramos on Mar 24, 2010 12:36 AM
Message 5 of 17
abilioramos
Here is an example from memory consumption between AutoCAD and PDMS. I have loaded the same project in AutoCAD and PDMS.
Can you see difference AutoCAD 700 Mb PDMS 3 Mb, yes only 3 Mb. Why???
What about Zoom, Move, 3DRotate? My god its BIG, ENORMOUS I don't have more adjectives to describe the difference. I will try to do a screen capture to show you the difference with Zoom, Move, 3DRotate between this to softwares.
Message 6 of 17
Hi Abilio,
I am unable to address your specific questions at this time but I did want
to relay to you that your posts have our full attention. Performance and
scalability is a major priority for us and we are looking into areas where
we can improve in Plant 3D. We are also looking into platform issues and the
possibily of additional features on the Plant 3D side to help working with
large models.
One tip I can provide for now is to turn off the display of connection
markers. You can do this via the ribbon or by typing PLANTCONNECTIONMARKER
at the command line and specifying a value of 0. This will should help as
the draw code of each component checks the connection state of every port to
determine whether a glyph is needed for display or not.
Thanks for your feedback.
Best regards,
Jorge Lopez
"abilioramos" wrote in message news:6358023@discussion.autodesk.com...
My questions are:
products?
Best Regards,
Abilio Ramos
Message 7 of 17
EileenForan
Hi Abilio,
As I read through your posts, I am wondering if you are speaking only of AutoCAD Plant 3D performance, or if you are also talking about AutoCAD's performance. If you are noticing a performance issue with AutoCAD, please let me know and I can connect with the AutoCAD team.
Eileen Foran
Eileen Foran
Community Program Manager
Autodesk Plant Solutions
Autodesk, Inc.
Message 8 of 17
Hi Jorge,
thanks for your tips but unfortunately speed and memory are not just a problem of plant3d but especially of autocad ...
The question is why AutoDesk products are getting slower in each version release instead of improving.
Best Regards
Lorenzo
Message 9 of 17
Abilio Ramos,
Thanks for your comments and your passion on this issue.
Comparing PDMS to Plant 3D is not a fair comparison at this point. PDMS has
been doing plant modeling for 20+ years and has been optimized for 3D and
only 3D. AutoCAD Plant 3D is in R1 and uses a general purpose cad engine as
it's platform. Autocad is used for many things and not solely optimized for
3D graphics. PDMS has the advantage of having a special purpose platform
that they've tuned to have great performance.
Having said that, we are not at all satisfied with the performance of
Plant3D. We are working along with the AutoCAD platform team to improve 3D
performance of Plant 3D. Improving performance, especially 3D performance,
is one of our top priorities.
Thanks again for your comments and questions,
Peter Quinn (Autodesk)
I'm not talking about AutoCAD Plant 3D only that is a Beta product, but also
produce faster than you. I'm a long time AutoCAD user for 15 years now and
My questions are:
Aren't NVIDIA, Microsoft, Autodesk partners?
Don't all work together to make better and faster products?
Why Autodesk products are getting slower in each version release, shouldn't
Don't you think its time to rewrite the graphic card code to improve it?
products?
Best Regards,
Abilio Ramos
Message 10 of 17
abilioramos
Yes Peter Quinn I know that, but try to say that to my boss, they only care is money and numbers.
My plants projects in AutoCAD Plant 3D, are faster when I start the software, but when I start moving around AutoCAD Plant 3D 2010 starts getting slower and slower and the memory consumption increasing a lot (100Mb to 700Mb), also Nvidia Quadro FX 1800 don't seen a good graphic card it starts showing, bad render and pixelized parts (I have tried tweak 3dconfig and Nvidia control panel but no results).
Here is the real reason why in so complaining, in my company, they have decided to invest in a new Plant Design Software, after a market consulting they have decided that the best Plant Software on the market is AVEVA PDMS.
We are 6 pipe drafters (some users with more them 20 years in AutoCAD), and all against the purchase of PDMS 12. We all vote for AutoCAD Plant 3D but my arguments against PDMS performance, database spec/catlog and others, didn't have any influence. So they decided to buy PDMS. I was so frustrated that I was trying to find here in the forum arguments to stop this deal.
After almost 15 years working with AutoCAD and Autodesk AutoCAD based products, I will have to learn a complete different software that have a complete different approach, or I can go unemployment 🙂
The damage is done I hope some day they realize that this investment was not so good, and them decide to go back to Autodesk products.
Please just keep doing the good work, trying to improve 3D graphic performance it will be crucial in large Plant Projects. I will keep following AutoCAD Plant 3D development and hooping one day go back to draw with it.
Sorry for any inconvenient,
Abílio Ramos
PS
I need to prepare my self psychologically to learn PDMS 😞 buaaaahhhhhh!!!!!!!
Message 11 of 17
dgorsman
I believe PDMS is database-backed, unlike Plant3D. This provides *very* fast management of the large volumes of data typically seen in overall plant models, along with a number of nice management tools for verification and mass changes. The downside of this is a cooresponding increase in overhead needed to manage those databases and a decrease in the flexibility to do radically different things. This makes it good for very large projects but not so much for the smaller, specialized ones. I would like to see some speed improvements but without running off a database (or one of those really big "aha!" software design moments) a large project will never run quickly in Plant3D.
After all, its all about choosing the right tool for the job - rubber mallet, claw hammer, or 10lb sledge?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 12 of 17
in reply to: dgorsman
We are having the same issues as the post above. We currently use Bentley and are testing Plant 3D. We also want to move to Plant 3D, but at what cost. The cost of the software is miniscule compared to losing a client because you can't get the project finished in time.
What we have found is that the performance is terrible. Just try xrefing a 30 meg drawing and time how long it takes to change views, 20-30 seconds, had no prior issues with Bentley running on top of AutoCad 2007 with 200 megs of Xrefs. Orbit, forget it, go get a cup of coffee and come back. I can send all kinds of files for the software developers to work with if they need to test it themselves.
 We are running I7 Zeon based workstations with 18 gigs of ram. I have been an Autodesk user for 13 years and paid subscription up until 2007 when I got tired of looking at new software sitting on my shelf that I installed and unistalled due to the fact that the programs ran slower. The 3D performance issue with AutoCad based products is not new. We have all seen what happens when you use 3D orbit and the many fatal crashes that occur in Land Desktop, Map 3D, Civil 3D, AutoCad and now Plant 3D.  Plant 3D should have not been released until the graphic engine was fixed.
 Buying software is not like buying any other consumer product that if it doesn't work you can send it back for replacement or refund, your stuck with it hoping for the next patch.
I may sound a little angry, but i'm more dissapointed. I think that in time Plant 3D will be a great product, but at this time it's a sheep in wolfs clothing.
Message 13 of 17
abilioramos
Hi, darryl_sharp
WELCOME TO MY WORLD!!!!
As you know AutoCAD IS NOT A 3D SOFTWARE ,I'm also 15 years AutoCAD user from Version 12 to 2011 I have never seen AutoCAD or AutoCAD based products perform well in 3D, it is getting slower in each version they release. Also the resources consumption is increasing in each version. I have a Plant 3D model that takes 1.5Gb of memory and each time I move around or pan the memory consumption keeps increasing up to 2Gb. Also each time I move, 3Dorbit or PAN I can take break for a coffee Smiley Happy
I remember the explode command on older versions that hoes just a click, now in the current versions sometimes it takes 5 minutes to finishing the command.
I don't think you will see AutoCAD Plant 3D perform well in 3D in the next years, they can't have PDMS performance because AutoCAD uses a complete 3D/Files/Database approach. I can guarantee it doesn't meter what expensive graphic card you buy it will not help you, I have Nvidia FX 4600 and I have seen AutoCAD Plant 3D perform better on a Geforce Graphic Card.
Unfortunately for me 100% AutoCAD lover, and I'm complete honest here, if you need performance or you have large Plant Projects them AutoCAD Plant 3D is not for you.
I hope one day they can make AutoCAD plant 3D perform has good has PDMS
Message 14 of 17
dgorsman
Buying software *is* unlike other consumer products.  Check with your car dealer to see if you can have a 30 day free trial, with the possibility of another 30 day extension on top of that.  Smiley Wink  And, until very recently, once that car was purchased the dealer wouldn't take it back either.  Most of them won't, after a point.  This is why trying it out is vitally important before laying out that kind of cash (car or software).
Me, I'm not disappointed in this software.  Slow?  Yes, much too slow.  Difficult to use? Almost impossible.  BUT I also recognize its also first generation software, so I don't expect them to hit a home run on their first step up to the plate.  For most corporate users first generation software is completely unsuitable.  It will always have bugs, along with limitations that are in place to speed up the development.  No point in developing fancy options if you need most of your budget to get the core program functioning efficiently.  Comparing it to software that has had generations of development across multiple releases of operating systems isn't really fair.  Users have been a little spoiled over the past few years as "new" software has been released which is little more than upgrades to established products, leading to expectations of immediate perfection in every product, first time, every time.
AutoDesk is stepping into the design cycle at a bad point with this program.  The yearly release cycle benefits established software the most, where they have had time to work out the major problems and now are in the process of adding a few new features or fine tuning existing ones.  The short cycle allows them to get these new features and fixes to market quickly.  A whole new software, though, needs major work done to its core programming during its initial stages which can look like product stagnation.  With a fixed budget (or even a reduced one, with economic considerations) this leaves little room for developing the new features that make for attractive sales pitches.  "We finally fixed the speed problems but we haven't gotten around to adding isometric views" doesn't read well to the executives who allocate funding.
Another cycle-related problem is the number of legacy models in place.  Companies that have been using other software to create models are unlikely to switch to a different program if it renders all that legacy data unusable.  Clients don't like it when a new EPCM is hired and has to redo entire models that it already has on file.
So, going forward, I think there are two major areas where the Plant3D team can make the most of their efforts at this early stage.  The first is to push the program for multi-threading data processing capability.  The application virtually begs for this development, which would directly improve speed.  Push the platform as a test bed, if you have to.  The second area addresses my last point above, which is dealing with legacy models.  AutoDesk could gain a great deal of good will from the piping community by establishing an open platform-independant piping data system, likely as an XML schema.  This would allow companies to more easily share models which will in turn make it much easier to adopt a newer program like Plant3D.  Those that want to use the program will not be shut out of multi-company collaborations simply because "we can't use that type of model".  If the standard is well thought out and well managed (volunteer commitee from industry with rotating chairpersons, probably) it will be easier for other software developers to adopt, getting over the whole don't-support-the-competitor stance.
And... thats lunch folks... Smiley Surprised
Message 15 of 17
Wotwentrong
abilioramos,
As a (reasonably) long term PDMS user / admin person, I welcome you to the world of PDMS!
It will be a grind to learn the system - it operates a little differently to CAD based systems. It certainly has advantages, and speed is one of them, but it shouldn't be considered the nirvana of 3D systems. It can 'sing and dance' but only with a lot of customisation and good operators. Size is one thing it does handle well though. It will handle almost unlimited native PDMS content. Drawings will eventually slow down, but you seldom get any glitches or downtime due to crashing.
It was actually developed back in the 70's! So yes it is optimised, but yet still carries baggage. Some features in v12 are very smart, whereas others seem to be stuck in the nineties.
Happy modelling!
Message 16 of 17
Hi abilioramos,
As a person who has used both PDMS and Plant 3D for real projects I should say that your company is doing you a favor not letting you get into the hassle and frustration of working with Autocad Plant 3D. I'm sure learning to work with a new software is not going to be easy but it would be far more easier than trying to the impossible, I mean sucessfully finishing a project in Plant 3D.
Regards
Message 17 of 17
@abilioramos
How is the work with PDMS going? Did you have success?
Thank you
