I have a cap and on it threadolet is placed
As it is seen in the screenshot, the red line is present, means connection is proper. I have given the name of the spool TESTA.
When I want to make a spool iso, with option of keep name manually from drawing, it is showing me error in generation. Error says that components are not connected. Can someone help me
Solved by h_eger. Go to Solution.
as there is no mm pipe, you will not get a complete isometric view.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
