Hola a todos, Cómo acceder a las propiedades de los objetos en plant3d, por lisp o por campo.
aluison2kLKPBT
aluison2kLKPBT
Por ejemplo, un objeto "Pipe"  tiene las mismas propiedades que en una "Linea" o un "Circulo" pero además, tiene muchas otras propiedades propias,  estas propiedades son las que necesito utilizar, y  no se pueden acceder a ellas desde la lista de campos.  Agradezco mucho su ayuda
DVaquand
Hello @aluison2kLKPBT
In Autolisp you can have limited access to certain properties and only read access.
Here is an example that reads the diameter of a selected component and displays the list of properties
(defun c:AP3D_ND_Proprerty ( / Select_Obj)
  (vl-load-com)
  (setq Select_Obj (vlax-ename->vla-object (car (entsel))))
  (print (strcat "ND = " (vlax-get-property Selec_Obj "size")))
  (princ "\n============================ Dump propriétés ================================\n")
  (vlax-dump-object Select_Obj)
  (princ)
Here are the different properties from the dump
; IAcPnP3dPipe: IAcPnP3dPipe Interface
; Property values:
; Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff7cdf9a178>
; CutLength (RO) = "1730.778568"
; Document (RO) = #<VLA-OBJECT IAcadDocument 00000164cefb5f88>
; EndType (RO) = "PL"
; EntityTransparency = "ByLayer"
; Facing (RO) = ""
; Handle (RO) = "56E"
; HasExtensionDictionary (RO) = 0
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0000016cd66f8928>
; InsulationThickness (RO) = ""
; InsulationType (RO) = ""
; Layer = "0"
; LineNumberTag (RO) = ""
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; Material = "ByLayer"
; MaterialCode (RO) = ""
; ObjectID (RO) = 42
; ObjectName (RO) = "AcPpDb3dPipe"
; OwnerID (RO) = 43
; PartFamilyLongDesc (RO) = "PIPE, SEAMLESS, PE, ASME B36.10"
; PlotStyleName = "Color_2"
; PnPClassName (RO) = "Pipe"
; PnPGuid (RO) = "579e9e5f-244e-48e6-9f92-0143aba1806a"
; PnPMaterial (RO) = ""
; PressureClass (RO) = ""
; Schedule (RO) = ""
; Service (RO) = ""
; Size (RO) = "4\""
; Spec (RO) = "CS900"
; Status (RO) = "New"
; Tag (RO) = ""
; TieInNumber (RO) = ""
; TrueColor = #<VLA-OBJECT IAcadAcCmColor 00000164c4b3abe0>
; Visible = -1
; WallThickness (RO) = ""
To go further into properties you have to switch to DotNet language
You have examples by loading the SDK
https://aps.autodesk.com/developer/overview/autocad-plant-3d-and-pid
== French ==
En Autolisp vous pouvez avoir un accès limité à certaines propriétés et seulement en lecture.
Voici un exemple qui lit le diamètre d'un composant sélectionné et affiche la liste des propriétés
Pour allez plus loin dans des propriétés il faut passer en langage DotNet
Vous avez des exemples en chargeant le SDK
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
aluison2kLKPBT
Thank you very much, that is the way;
