- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello guys.
thanks for all the previous help you have provided me.
Today I faced a new issue regarding Specs Editor. I cannot find the custom components in the 'Add new Component' section. I have checked and rechecked all the setting. All pyhthon script loaded into ContentFolder\CPak Common\CustomScripts and I have also verfied the content folder path in specs editor. Its pointing to the same directory. Untill this morning everything was working finenand all my components were showing and being used the 3D model effectively. The only change in the last couple hours is that I have created a new component and now nothing is shown in the 'Add New components' and only the default parts that comes with Autocad.
I am totally dumbstruck here because if it was a problem with content folder location and its vector, none of my 3D components should have been shown in the 3D model. Instead I should have get the message "can't find the symbol for specified part" but thats not happening. Components are working fine in everyway but can't add new because I can't find any even those already in the specs. It doesn't look like relating to script as well because before the latest script all were showing in the specs editor so why not now (still I tried removing the latest script and also tried emptying the scripts folder and compiled freshly to generate new ScriptGroup and Varients XMLs). The component being created by this latest script also doesn't have any coding problem because TESTACPSCRIPT is succesfully loading it.
So I am now literally dumbstruck on what to do next. The onky thing I haven't tried is reinstalling the AutoCAD P3D from scratch and I'd rather avoid it if I can. Any help guys??
