Unable to copy a drawing to project
philip_pomery9YM8C
philip_pomery9YM8C
We are using projects directly off our server and not through BIM360 or any other ways. Last week I was working from home and accessing files on the server through VPN. I had to go out in the middle of the day and when I came back the VPN had disconnected. The file cannot be accessed now unless I open it outside the project. When I try and add it to the project, I get the following. I have tried all the tricks that are suggested by Autodesk but nothing seems to work
h_eger
Dear @philip_pomery9YM8C ,
Your drawing is still available in the project database.
Until this drawing is completely removed from the project database, you cannot add your edit copy to the project.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
