AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Spec part
1 REPLY 1
regarderasmus4
264 Views, 1 Reply
Spec part
Can anyone tell me what is the SPEC PART  - I see that the there is property name under the P&ID inline and lines called spec part.
For some reason it apaer as a list but if I look in Datamanger the detail shows.
Is this something that is added or created in Spec Editor?
Thank you,
1 REPLY 1
h_eger
in reply to: regarderasmus4
Dear @regarderasmus4 ,
this Spec Part field is required for Spec Driven P & IDs
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/CloudHelp/cloudhelp/2021/...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
