AutoCAD Plant 3D Forum
Some pipe fittings not showing in the model
4 REPLIES 4
santoshbaraiya
279 Views, 4 Replies
I am making a 3d drawing in plant3d. After a day I opened the model and some of the pipe fittings are not showing, like elbows, flanges and tees. The connection is there. When I right click and select add to selection and select all connecting parts, then it connects the pipe.
I have attached the screenshot.
Can anyone help me with this issue
4 REPLIES 4
h_eger
in reply to: santoshbaraiya
@santoshbaraiya ,
FASTSHADEMODE = OFF
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
That didn't work but I found a unusal way.
I deleted that spool and undo the delete. Magically all the fittings appeared.
May be some glitch in the graphics I guess.
Try the command “PLANTSHOWALL”
李榕华
13489140049@qq.com
jflorita
I have encountered this and "REGENALL" worked perfectly.
