I am making a 3d drawing in plant3d. After a day I opened the model and some of the pipe fittings are not showing, like elbows, flanges and tees. The connection is there. When I right click and select add to selection and select all connecting parts, then it connects the pipe.
I have attached the screenshot.
Can anyone help me with this issue
Solved by santoshbaraiya. Go to Solution.
FASTSHADEMODE = OFF
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
That didn't work but I found a unusal way.
I deleted that spool and undo the delete. Magically all the fittings appeared.
May be some glitch in the graphics I guess.
