AutoCAD Plant 3D Forum
Showing CADWorx objects in Plant 3D
2 REPLIES 2
A-Steele
1355 Views, 2 Replies
A-Steele
I am attempting to open a file in AutoCAD Plant 3D 2019 that contains CADWorx objects.  I have installed the CADWorx Object Enabler 2018 but the objects are still showing as ACAD Proxy Entities with box in there place.  I have uninstalled and reinstalled the Object Enabler to no avail.  How con I get these objects to show as they were intended?  Any help would be greatly appreciated.  Thanks.
2 REPLIES 2
jw7018
in reply to: A-Steele
jw7018
If you do not need the model intelligence you could export  the Cadworx file to a (.SAT) file and bring it in like an Xref.
I've opened a Cadworx file  in plant and is only showed the center line of the piping.
dgorsman
dgorsman
Stupid question time: are you certain the OE installed and is recognized?  Does the OE support the version of AutoCAD/Plant3d you are using?
What version of DWG file are you saving the file as?
