AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Set points in custom script components
2 REPLIES 2
378 Views, 2 Replies
I've managed to create a component but having trouble with the points. When I inserted my support into a pipe with a matching diameter, the component's plant connection markers keeps on popping out and I've set my points into (0,0,0) in my script. What does it mean??
Tags (1)
2 REPLIES 2
h_eger
Dear @Anonymous ,
did you stick to the following program code regarding setPoint?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
Thanks for the answer. I did follow the initial pattern for the setPoint. But I have an instance that when I place my custom component into the pipe. The pipe should be positioned in the back of the component instead it pass through the component like a barbeque where my point is place. Btw I manipulate the object to move from the point of origin so that I can make the Point of origin as the point where the components connect.
Thanks for the reply.
