How can i get the slope symbole on isometric when a reducer is used?
I noticed that as soon as a reducer is placed on a piece of pipe the slope symbole does not show
Regards
It works for me - see my settings below:
<!-- Skew configuration --> <!-- 'Skew2d': Can be 'Box', 'BoxWithTriangle', 'TrianglePlusNormalDimensioning', or 'TrianglePlusAlternativeDimensioning'. --> <!-- 'Skew3d': Can be 'Box', 'BoxWithTriangles' or 'DoubleTriangles'. --> <!-- 'IncludeBranches': Set 'true' to include the whole pipeline in a skew. 'false' to split at branches (i.e. Tees). --> <!-- 'Slope': Can be 'TrianglePlusFallIndicator', 'Box3d', or 'DoubleTriangles'. --> <!-- 'SlopeSymbolType': Can be 'Ratio', 'Percent', 'Angle', 'Gradient', 'ImperialIncline', 'MetricIncline', or 'SuppressFallIndicator'. --> <!-- 'NonSkewAngleTolerance': The angle tolerance below which the branch is not taken as skewed. --> <!-- 'FallPercentage': (0.0 - 100.0) --> <!-- The percentage of rise over run, below which the skew will be considered as a fall. --> <!-- 'HatchPatternScale': (double) --> <!-- The hatch pattern scale for a skew triangle. --> <!-- 'HatchColorIndex': (0 - 256) AutoCAD Color Index (ACI) --> <!-- Use the COLOR command to get a list of index values. --> <!-- 0 = ByBlock --> <!-- 256 = ByLayer --> <!-- 'HatchBoundaryFillAmount': (0.0 - 1.0) --> <!-- The fraction of a skew triangle to fill up with a hatch. --> <!-- 0.25 = 25%; one quarter of the skew triangle will be hatched. --> <!-- 1.00 = 100%; the entire skew triangle will be hatched. --> <!-- 'StackingRatio': (0.0 - 1.0) --> <!-- 'HAngleSuffix': one letter. Default to 'H' --> <!-- 'VAngleSuffix': one letter. Default to 'V' --> <!-- 'SkewDimAngularStyle': Can be 'DimAngularOff', 'DimAngularWithoutSuffixNorArc', 'DimAngularWithSuffix', 'DimAngularWithArc', or 'DimAngularWithSuffixAndArc'. --> <!--RightAngleSize:--> <!-- RightAngleColorIndex: Acad color index from 0 to 255--> <Skew Skew2D="TrianglePlusAlternativeDimensioning" Skew3D="DoubleTriangles" IncludeBranches="true" Slope="TrianglePlusFallIndicator" SlopeSymbolType="Percent" SlopeSymbolBelowPipe="true" SlopeSymbolOffset="0.2" MaxSlopeAngle="5" MinSlopeRatio="0.001" NonSkewAngleTolerance="1.5" SkewToleranceEqualPoint="0.01" HatchPatternScale="0.03125" HatchColorIndex="256" HatchBoundaryFillAmount="0.25" HatchPatternName="LINE" HatchOffset="0.1875" StackingRatio="0.33" HAngleSuffix="H" VAngleSuffix="V" EnableDimension="true" SkewDimAngularStyle="DimAngularWithSuffixAndArc" DimAngularTextOffset="0.625" RightAngleSize="0.2" RightAngleColorIndex="1"> <!-- 'SlopeSymbols' --> <!-- 'Key': (string); References the 'SlopeSymbolType' attribute above. --> <!-- 'Value': (string); References a block definition name in the symbol library drawing --> <SlopeSymbols> <Item Key="Angle" Value="AnnoSlopeAngle" /> <Item Key="Ratio" Value="AnnoSlopeRatio" /> <Item Key="Percent" Value="AnnoSlopePercent" /> <Item Key="Gradient" Value="AnnoSlopeGradient" /> <Item Key="ImperialIncline" Value="AnnoSlopeImperialIncline" /> <Item Key="MetricIncline" Value="AnnoSlopeMetricIncline" /> <Item Key="SuppressFallIndicator" Value="AnnoSlopeTriangle" /> </SlopeSymbols> </Skew>
