AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Saving drawings to a pdf or creating a snapshot view of P&ID drawings feature
4 REPLIES 4
mohammed_cameGQHXZ
262 Views, 4 Replies
I am currently doing my thesis using AutoCAD plant 3D.  I have divided my P&ID into three seperate drawings due to space constraints and wanted to know if theres a feature to convert the drawings to a pdf instead of taking screenshots of the drawings as the qquality is poor and not very visible as I have to include this in my written section of my thesis. Additionally, is there a feature to combine all three drawings in a way? Like having them in one pdf or image of the three seperate drawings. This would be very helpful to know
4 REPLIES 4
You can use the publish option:
set to print as pdf (1)
choose your different drawings and whether you want to print the model space or the layout space (2)
publish (3)
in the settings you can choose to print as one multipage pdf and find other settings
Or use the regular PLOT command (ctrl+p)
set your printer (1) what to print (2) and other settings (3)
Check the help files or one of many youtube video's for more information on how to publish/plot:
https://help.autodesk.com/view/PLNT3D/2025/ENU/index.html?guid=GUID-2415687F-0064-4AC8-AC52-AAEF9AD0...
https://help.autodesk.com/view/PLNT3D/2025/ENU/index.html?guid=GUID-2DB9EB8C-767C-4C91-B0A3-FFFEC4C5...
h_eger
in reply to: mohammed_cameGQHXZ
@mohammed_cameGQHXZ ,
print as Dwg to Pdf.pc3
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
mohammed_cameGQHXZ
in reply to: h_eger
Yes thank you very much!!
Yes thank you very much !!!
