- Mute
- Permalink
- Report
Good morning,
My name is Nicolas,
I am testing my custom catalog in Report Creator.
I´ve routed a few pipe to create a Report and see how the programm shows all the elements, i have pipes with different OD, for example pipe 250 mm diameter with OD 250 and 280, pipe 150 mm diameter with OD 160 and 180 and so on. In the report the pipe 250 mm routed with the 2 different OD appear as one, Report counts both of them together instead of separating them in 2 different rows, programm dont make distinction between different OD, the same happens to the rest of pipes and elbows.
In the Bill of Material of the pipes isometric everything is listed correctly, the table make distinction of different OD pipe at the moment of counting material.
I don´t know if anybody have the same problem as me and have solved it.
I attach 2 images and the Report PDF to explain the problem.
Thanks.
