Report Designer pipe and fittings with 2 OD
MONTECINOS
Message 1 of 9
MONTECINOS
Good morning,
My name is Nicolas,
I am testing my custom catalog in Report Creator.
I´ve routed a few pipe to create a Report and see how the programm shows all the elements, i have pipes with different OD, for example pipe 250 mm diameter with OD 250 and 280, pipe 150 mm diameter with OD 160 and 180 and so on. In the report the pipe 250 mm routed with the 2 different OD appear as one, Report counts both of them together instead of separating them in 2 different rows, programm dont make distinction between different OD, the same happens to the rest of pipes and elbows.
In the Bill of Material of the pipes isometric everything is listed correctly, the table make distinction of different OD pipe at the moment of counting material.
I don´t know if anybody have the same problem as me and have solved it.
I attach 2 images and the Report PDF to explain the problem.
Thanks.
Replies (8)
Message 2 of 9
h_eger
Dear @MONTECINOS ,
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-create-a-re...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 9
MONTECINOS
Good morning Hartmut,
Thanks for your answer.
I followed all the instruction of the link that you sent to me, i changed the values but everythigns keeps the same
Message 4 of 9
jabowabo
Message 5 of 9
MONTECINOS
Hello Jason,
Thanks for your answer, according to your message i completed the rest of the configuration, now the Report Configuration separating pipes according to the different OD works correctly but now the Report is adding for example all the elbows of different diameters in only one adittion, the same happen to the rest of fittings and also the configuration of the template got misconfigurated.
Message 6 of 9
MONTECINOS
Good morning,
I have already fixed the problems.
Thanks for your help.
Message 7 of 9
MONTECINOS
Hi again,
I solved all the problems that i had with the Report Creator, but a new unexpected problem emerged, all the pipe are separated by diameter, that´s ok, but the programm has separated everysingle piece of pipe in the total amount, for example let´s imagine that i route 3 sections of pipe NS 250mm with 2 elbows, the Report don´t count the total amount of pipe of that size, Report counts separately everysingle section of pipe instead.
¿How can i solve this?.
I attach 2 images to explain the problem.
Cheers.
Message 8 of 9
jabowabo
Remove the weight and quantity sort fields. Anything you want a calculated sum of should not be a sort field. Sorry, I wasn't clear on that earlier.
Message 9 of 9
MONTECINOS
Hi Jason,
Thank you very much.
I followed the last tip that you gave me and the Report Creator is working correctly right now.
Cheers.
