Report Creator Lockup
Stormbr
Message 1 of 15
Stormbr
Changing the cell alignment or border causes the report creator to lock up. I can change any other cell except that one.
I have been able to change most of the attributes of that cell but not the alignment or border.
Some of the other cells seem to change the setting back for font after I have set it to a specific size.
In the format editor the same issue occurs - lockup after the border or alignment is changed.
The report was a copy of the 3D Parts report with some tweaks.
Replies (14)
Message 2 of 15
h_eger
Dear @Stormbr,
Version of Plant 3D?
Environment of Plant 3D:
local
network
collaboration
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 15
Stormbr
P3D 2018.1
Local standalone.
Message 4 of 15
h_eger
Windows 10 1709?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 15
Stormbr
Correct. Win 10 Home.
I copied the report and modified it but same issue, locks up if I change alignment or borders.
Message 6 of 15
h_eger
Dear @Stormbr,
Sorry I can not reproduce your problem with the report creator
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 15
Stormbr
This is the report. I think there is something wrong with the report file. It works to produce the report but the format is wrong. Trying to fix the format locks up the program.
The attachment is the report file but renamed to allow it to be attached. Rename it back to an RCF.
Message 8 of 15
ryan.bales
Autodesk Support
Autodesk Support
Hmm, the attached file is corrupted.
Can you recreate the report?
Ryan Bales
Fusion 360 Product Support
Message 9 of 15
Stormbr
Thanks Ryan, I recreated the report but same issue. I started again from the 3D Parts report, made a copy, edited it & it worked. I will just scrap the original report. It worked to make the report but I couldn't edit the last field.
Message 10 of 15
jhamilton
Mine locks up when trying to do the text justification also.  Another person here has the same problem.  Really annoying.
Message 11 of 15
h_eger
Dear @jhamilton,
please version of Plant Report Creator and Report File uploading
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 12 of 15
jhamilton
It is Plant 3d 2018 Report Creator.  Latest updates have all been installed.  It is Windows 10.   The report files are not corrupt.  My reseller was able to duplicate this.  It may be a conflict with a recent windows 10 update.
Message 13 of 15
Peter_Jansoone
I'm also having this problem, in versions 2016,2017,2018 with all SP and updates. Very annoying, prevents creating a decent report layout
Peter Jansoone
Plant Design software consultant at Arkance Systems Belgium
Message 14 of 15
Hi Hartmut,
I've noticed your replies, as I'm also having this exact issue, and am currently running Windows 10 Enterprise, version 1709, and Plant3D 2018.2, on enterprise
I am curious what your solution involves thanks?
Cheers,
Message 15 of 15
jhamilton
Then end result on this is that there is an conflict with the 2018 report creator and Windows 10 updates.  You do have some work around's.  If you are wanting to change the border of a cell, just type in what it needs to be instead of using the drop down selection.  The drop down section is what is locking up.  You can type "All" or "None" or "Left, Right,Top,Bottom" and it works fine.  You can use the few text justifications on the top ribbon as well to change the text justification.  Other than this, everything works fine.
Note:
You can use Plant 3d 2018/2019 interchangeably.  In other words you can take a 2018 project and open it in 2019, and then go back and still open it in 2018.  However if you open and save a report creator file in 2019, you can not go back to 2018 report creator.  But this does not affect opening the project in plant 3d 2018, just report creator 2018.
