This is my first time for custom AutoCAD Plant 3D. Could some one explain me how to read Data Manager just for Engineering Items using VB.Net
This code below read all data in data manager. But can't read new data if I add new item/symbol.
Here's my code :
Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.ProcessPower.ProjectManager Imports Autodesk.ProcessPower.PlantInstance Imports Autodesk.ProcessPower.DataLinks Imports Autodesk.ProcessPower.Styles <Assembly: ExtensionApplication(Nothing)> Namespace DataManagerCon Public Class DataManageCon 'test connection to PID Data Manager <CommandMethod("TestConnection")> Public Sub TestPnPID() 'Menghubungkan Net ke Plant 3D Dim myDb As Database = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database 'Koneksi ke data links manager Dim myDlm As DataLinksManager = DataLinksManager.GetManager(myDb) 'Mengakses data P&ID untuk project yang sedang aktif Dim myProject As Project = PlantApplication.CurrentProject.ProjectParts("PnId") 'Mengambil Data Gambar Yang sedang aktif Dim myProjectDrawings As List(Of PnPProjectDrawing) = myProject.GetPnPDrawingFiles() Dim sProperties As String = String.Empty Dim myRowIDs As Autodesk.ProcessPower.DataObjects.PnPRowIdArray = myDlm.SelectAcPpRowIds(myDb) For Each myRowID As Integer In myRowIDs Dim myProperties As List(Of KeyValuePair(Of String, String)) = myDlm.GetAllProperties(myRowID, True) For Each myProperty As KeyValuePair(Of String, String) In myProperties If myProperty.Key.ToUpper = "MANUFACTURER" Or myProperty.Key.ToUpper = "CLASSNAME" Then sProperties = sProperties & myProperty.Key.ToUpper & ":" & myProperty.Value End If Next sProperties = sProperties & vbNewLine Next MsgBox(sProperties) End Sub End Class End Namespace
Do new items show in the results after you save the file?
I think your issue is related to how you are retrieving the DataLinksManager. The following C# code works as expected:
// get current dwg stuff Document doc = Application.DocumentManager.MdiActiveDocument; Editor ed = doc.Editor; Database db = doc.Database; // get P3D stuff PlantProject currentProj = PlantApp.CurrentProject; PnIdProject pnidProj = (PnIdProject)currentProj.ProjectParts["PnId"]; DataLinksManager dlm = pnidProj.DataLinksManager; // List of properties to report List<string> reportProps = new List<string>() { "MANUFACTURER", "CLASSNAME" }; // Create message string string reportMsg = ""; // get rowIds associated with current drawing database PnPRowIdArray rowIds = dlm.SelectAcPpRowIds(db); // iterate rowIds foreach (var rowId in rowIds) { reportMsg += $"\nrowId : {rowId}"; List<KeyValuePair<string, string>> props = dlm.GetAllProperties(rowId, true); // iterate properties foreach (var prop in props) { string propKeyUp = prop.Key.ToUpper(); // report properties if (reportProps.Contains(propKeyUp)) { reportMsg += $"\n\t {prop.Key} : {prop.Value}"; } } reportMsg += Environment.NewLine; } ed.WriteMessage(reportMsg);
I'm trying the read the LineNumberTag from a pipe from within an Orthographic drawing (I know the handle of the pipe in the 3D Model from xdata on the Orthographic representation):
((-1 . <Entity name: 125a1b23f10>) (0 . "INSERT") (5 . "CD1") (102 . "{ACAD_XDICTIONARY") (360 . <Entity name: 125a1b278c0>) (102 . "}") (330 . <Entity name: 125abe071f0>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "Top (Plan) View-PIPING") (100 . "AcDbBlockReference") (2 . "*U27") (10 0.0 0.0 0.0) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 1.0) (-3 ("PnPOrthoApp" (1071 . 901) (1005 . "35E") (1071 . 0) (1000 . "Piping") (1000 . "{ACDD082F-9A28-284A-8616-7ADCEC8A0F9C}"))))
So far I've only been able to read the information via the Data Link Manager when I'm in the 3D Model and not from within the Orthographic drawing. In fact, if I try to open the Data Manager palette from the Orthographic Drawing nothing is displayed - any clues on that?
The DataManager window doesn't open while Plant 3D is in Ortho drawing context. You can only get a model entity's ObjectId while the model is open - this is because ObjectId is not persistent between sessions, while Handles are.
You can use the DwgId and the handle (translated to DwgHandleLow) to query the PnPDataLinks table to find the model item rowId. With the rowId, you can find the properties in whichever tables it exists in.
Thanks Jason, that helped. My handle is "35E" that converts to a DwgHandleLow of 862 which does indeed lead me to the required RowId of 1065:
However, to find that DwgHandleLow I looped through 1066 rows and for each calling:
List<KeyValuePair<string, string>> props = dlmgr.GetAllProperties(i, true);
Is there a way I can get those Properties directly with a query without having to loop through each row until I find it?
Much appreciated, Simon
There's no need to loop through the rows. You can query the datalinks table for the row with the same DwgId and DwgHandleLow. From here, you get the RowId, which you can use to get the properties from dlm. If that's not clear, DM me your code and I'll take a look.
