AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
"Geometry can not be generated with the given parameters"
3 REPLIES 3
943 Views, 3 Replies
I am attempting to create a custom pipe support.  I followed the guides I found here and here (yeah, I know it's old, but it had all the different primitive shapes and their arguments). Code is included at the bottom of this post.
I am able to view the part in the spec editor, and add it to a pipe support spec.  However, when trying to place the component, I got the following errors:
> Geometry can not be generated with the given parameters.
> Can't find symbol for specified part.
I tried looking this issue up, and found these answers.  I attempted these solutions, but it did not solve the problem.
Additionally, I can't seem to figure out how to allow my pipers to change individual values after placing the component, while still having a default value.  Specifically, L3 and H5 (below) should have default values (24 and 48 respectively), but be able to be changed by the drafter after placing the support.  I haven't tried to implement this yet because I couldn't get the static object to work, but I'm not sure how to go about it either, so suggestions would be awesome!
from aqa.math import *
from varmain.primitiv import *
from varmain.var_basic import *
from varmain.custom import *
@activate(Group="Support,Base Support", FirstPortEndtypes="Undefined_ET",
TooltipShort="Base Pipe Support", TooltipLong="Base Pipe Support by DB and SD", LengthUnit="in", Ports="1")
@group("MainDimensions")
@param(H6=LENGTH, TooltipLong="Support Pipe A height")
@param(D6=LENGTH, TooltipLong="Support Pipe A diameter")
@param(H5=LENGTH, TooltipLong="Support Pipe B height")
@param(D5=LENGTH, TooltipLong="Support Pipe B diameter")
@param(L2=LENGTH, TooltipLong="Plate C side length")
@param(H2=LENGTH, TooltipLong="Plate C thickness")
@param(L1=LENGTH, TooltipLong="Plate D side length")
@param(H1=LENGTH, TooltipLong="Plate D thickness")
@param(W3=LENGTH, TooltipLong="Angle E width")
@param(H3=LENGTH, TooltipLong="Angle E thickness")
@param(PD=LENGTH, TooltipLong="Pipe Outer Diameter")
def BaseSupport001(s, L1=10.0, H1=0.5, L2=6.0, H2=0.5, L3=24.0, W3=2.5,
H3=0.25, D5=2.375, H5=36.0, D6=1.875, H6=9.0, PD=4.5, **kw):
# define sizes
W1=L1
W2=L2
R5=D5/2
R6=D6/2
O5=R5/2
O6=R6/2
TH=H1+H2+H3+H5+H6+PD/2
# define the shapes
b1 = BOX(s, L1, W1, H1).translate(0.0, 0.0, H1/2)
b2 = BOX(s, L2, W2, H2).translate(0.0, 0.0, H1+H2/2)
b3 = BOX(s, L3, W3, H3).translate(0.0, 0.0, H1+H2+H5+H6+H3/2)
b4 = BOX(s, L3, W3, H3).translate(0.0, W3/2, H1+H2+H5+H6+H3/2-W3/2).rotateX(90.0)
c1 = CYLINDER(s, R5, H5, O5).translate(0.0, 0.0, H1+H2)
c2 = CYLINDER(s, R6, H6, O6).transalte(0.0, 0.0, H1+H2+H5)
# combine all objects
b1.uniteWith(b2)
b2.erase()
b1.uniteWith(c1)
c1.erase()
b1.uniteWith(c2)
c2.erase()
b1.uniteWith(b3)
b3.erase()
b1.uniteWith(b4)
b4.erase()
#Connection points
s.setPoint((0, 0, TH), (0, -1, 0))
(if it matters, the O1=R1/2 and O2=R2/2 lines are just there to ensure that O is always positive and non-zero.  We don't care about the inside of this pipe, just the outside)
3 REPLIES 3
jabowabo
See comments below. You've got some geometry locations to fix but this will generate the items.
@activate(Group="Support,Base Support", FirstPortEndtypes="Undefined_ET", TooltipShort="Base Pipe Support", TooltipLong="Base Pipe Support by DB and SD", LengthUnit="in", Ports="1")
@param(L3=LENGTH, TooltipLong="???????????????????")# You left this one out
def zzTest01(s, L1=10.0, H1=0.5, L2=6.0, H2=0.5, L3=24.0, W3=2.5, H3=0.25, D5=2.375, H5=36.0, D6=1.875, H6=9.0, PD=4.5, **kw):
    # define sizes
    W1=L1
    W2=L2
    R5=D5/2
    R6=D6/2
    O5=R5/2
    O6=R6/2
    # define the shapes
    # b0 = BOX(s, L=1, W=1, H=1) <-------- mind dim data format for BOX
    b1 = BOX(s, L=L1, W=W1, H=H1).translate((0.0, 0.0, H1/2)) # Translate requires double parentheses
    b2 = BOX(s, L=L2, W=W2, H=H2).translate((0.0, 0.0, H1+H2/2))
    b3 = BOX(s, L=L3, W=W3, H=H3).translate((0.0, 0.0, H1+H2+H5+H6+H3/2))
    b4 = BOX(s, L=L3, W=W3, H=H3).translate((0.0, W3/2, H1+H2+H5+H6+H3/2-W3/2)).rotateX(90.0)
    # b0 = CYLINDER(s, R=1, H=1, O=1) <-------- mind dim data format for CYLINDER
    c1 = CYLINDER(s, R=R5, H=H5, O=O5).translate((0.0, 0.0, H1+H2))
    c2 = CYLINDER(s, R=R6, H=H6, O=O6).translate((0.0, 0.0, H1+H2+H5)) # misspelled translate here
    b1.uniteWith(b2)
    b2.erase()
    b1.uniteWith(c1)
    c1.erase()
    b1.uniteWith(c2)
    c2.erase()
    b1.uniteWith(b3)
    b3.erase()
    b1.uniteWith(b4)
    b4.erase()
    #Connection points
in reply to: jabowabo
Thanks!  That did it.  It now loads and I was able to play with the geometry and make it work.
Do you know how to make grip points that I can use to change the shape length?  According to the guide I was using, setting a variable to a negative number would work, but that leads to the same error I had before.
jabowabo
#### Stretch Points:
# - sets value of @param variables only
# - 'MyDim' = param value to set
# - first (<coords>) = start position
# - second (<coords>) = end position (grip location) s.setLinearDimension('MyDim', (0, 0, 0), (0, 0, MyDim))
Technology Administrators
