Python - Pass value to test script
Is possible to pass values to a test script?  Either directly or by reading from a text file. Thanks.
h_eger
Dear @Anonymous,
these two variants for the test script are available to you.
TESTACPSCRIPT / TESTACPSCRIPT1
To test and check the geometry body we have the AutoLISP® function TESTACPSCRIPT and TESTACPSCRIPT1 created.
The first parameter at booth script types is the variants name (like "CPFLR")
The next parameters for TESTACPSCRIPT are couples of values: the fieldname and the needed value (like "D1" "300.5").
For TESTACPSCRIPT1 we have to set all the parameters inside 1 string (like it’s done inside catalog/spec dbs: “D1=300.5”)
If a field isn't set the function takes the default values from the variants definition.
That looks like:
(TESTACPSCRIPT "CPFLR")
(TESTACPSCRIPT "CPFLR" "D1" "300.5")
(TESTACPSCRIPT "CPFLR" "L" "40" "D1" "300.5" "D2" "88.9")
Or
(TESTACPSCRIPT1 "CPFLR")
(TESTACPSCRIPT1 "CPFLR" "D1=300.5")
(TESTACPSCRIPT1 "CPFLR" "L=40,D1=300.5,D2=88.9")
Before we can use TESTACPSCRIPT or TESTACPSCRIPT1 inside Plant 3D we have to load PnP3dACPAdapter.arx.
That can be done with
(arxload "PnP3dACPAdapter.arx")
or with the appload function
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Thank you. Where is that excerpt from?
h_eger
Dear @Anonymous,
Internal documentation of Autodesk development
Hartmut Eger
Senior Engineer
XING | LinkedIn
