How to make line number tag visual in 3D model?
m.bevers
m.bevers
Okay, gonna try and explain what I'd like to know Smiley Very Happy:
Is there a way to make line numbers visual (as text) in a 3D model?
Right now in plant3D I create a Mtext, manually type the correct line number and then place the text next to the corresponding pipe, like this:
(plant 3D screenshot)
With the goal to make line numbers visual in Navisworks, so our clients can easily see what they are looking at.
2018_05_17_11_50_30_Lijn3_F50_and_TRIPLE_UNITS.nwf_Autodesk_Navisworks_Simulate_2017.jpg
(Screenshot from Navisworks. What I'd like to see)
Doing it like I mentioned above is a lot of work, a potential threat for human errors and when changing a pipe route or line number you also have to manually move/change the mtext of course... So it's a PITA Smiley Tongue
Is it possible to make something where you just click a piece of pipe and have p3d automatically place the line number text near the point where you clicked?
Perhaps a component that one can select from the pipe spec tool palettes and insert somewhere in a pipe (like a little name plate or something..)
Hi,You can only do this through P3D development. If you need ,I can help you.   My email is  [email protected]
Dan.Scales
Hi @m.bevers,
Unfortunately the functionality that you describe is not currently available in Plant 3D.
Dan
Dan Scales
jabowabo
Here's an example with LISP.
; [email protected]
; Note: Current mleader style needs to be type Multileader Type: "Mtext"
(defun c:TagLine ( / myEnt vlaobj lineNumTag mlObj)
  (vl-load-com)
  ; get the line number from piping obj
  (setq myEnt (car (entsel)))
  (setq vlaobj (vlax-ename->vla-object myEnt))
  (setq lineNumTag (vlax-get-property vlaobj 'LineNumberTag))
  ; create the mleader.
  (command "_MLEADER" pause pause "")
  ; change mleader text to line number tag
  (setq mlObj (vlax-ename->vla-object (entlast)))
  (if (= (vlax-get-property mlObj 'ObjectName) "AcDbMLeader")
    (vlax-put-property mlObj 'TextString lineNumTag)
    (exit)
  (princ)
