Plastic specification
hholgadoSQKLP
hholgadoSQKLP
I'm creating a plastic specification using PE100.
The pipes and fittings uso outside diameter OD, the valves and flanges norminal diameter ND.
For the example i want to connect; Pipe OD110 → stun end OD110/DN100 → flange ND100
My Stub End has two nominal diameters:
  • ND1 = ND100 (FL)
  • ND2 = OD110 (PPL)
The catalog stores both values correctly.
However, when the Stub End is inserted automatically by a Connection Rule, Plant 3D changes one of the ports so both ports end up with the same nominal diameter.
A Reducer with ND1 ≠ ND2 works correctly, but the Stub End does not.
Is there any setting or Part Family property that allows a Stub End to preserve ND1 and ND2 during automatic insertion?
Or the ir another form to do this possible?
hholgadoSQKLP
i think i must to configutate this windows
lauri_barnhart
Hello, @hholgadoSQKLP.
Thank you for posting your question. If you can provide an additional information such as the product and product version or any screen recordings showing information in real time that would be helpful.
Best,
Lauri | Community Manager
