Plastic specification
- Mute
- Permalink
- Report
I'm creating a plastic specification using PE100.
The pipes and fittings uso outside diameter OD, the valves and flanges norminal diameter ND.
For the example i want to connect; Pipe OD110 → stun end OD110/DN100 → flange ND100
My Stub End has two nominal diameters:
- ND1 = ND100 (FL)
- ND2 = OD110 (PPL)
The catalog stores both values correctly.
However, when the Stub End is inserted automatically by a Connection Rule, Plant 3D changes one of the ports so both ports end up with the same nominal diameter.
A Reducer with ND1 ≠ ND2 works correctly, but the Stub End does not.
Is there any setting or Part Family property that allows a Stub End to preserve ND1 and ND2 during automatic insertion?
Or the ir another form to do this possible?
