3D Electrical Design in Plant 3D 2024
JVS_YYCMRDK8
JVS_YYCMRDK8
Hello everyone,
I did search the forum and there was some older posts on this subject, but thought I would try to find out some more current information. We are in the planning stages of a large project that we are going to use Plant 3D 2024. We are not using the P&ID package, just 3D. We are looking for ideas on the best way to model electrical to integrate with Plant 3D.  We originally was going to use AutoPLANT Raceways, but AutoPLANT is retired at the end of 2024. So now we are looking for something else. We did come across this Python script in the Autodesk store, but not sure if this would be the correct approach. We would probably need more than just cable trays.
https://apps.autodesk.com/PLNT3D/en/Detail/Index?id=5679577637251598566&appLang=en&os=Win64
I have read on here on others using Revit or AutoCAD Electric for this. We are also going to integrate this with Autodesk Construction Cloud. We are looking for the best electrical package to use with Plant 3D. Does anyone have any suggestions on this?
On a side note, I don't understand why Autodesk has not put an electrical package in Plant 3D. Doesn't make sense to me.
Thank you,
h_eger
Dear @JVS_YYCMRDK8 ,
For me, it makes a lot of sense not to integrate AutoCAd Electrical into Plant 3D because I am trained in both disciplines and the complexity of Plant 3D is a big challenge. Now AutoCAD Electrical is added to the mix and many people would not be able to do much with it. This is exactly the same as AutoCAD Plant 3D and Advence Steel, which would fit together even better, but here, too, the programs are overloaded for the users.
In addition, AutoCAD Electrical does not contain any EN ISO content and guidelines. So we would be a bit bored in the EU.
We work with EL-CAD or EPlan in cooperation with Plant 3D
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
JVS_YYCMRDK8
Do you know if EL-CAD or EPlan has a collaboration component, to work with Construction Cloud?
h_eger
Construction Cloud is unfortunately only for Autodesk products and not for Extene CAD programs
You can of course manage the documents of your EPlan work in the Constraction Cloud and derive processes, but you cannot create an on demand link.
Hartmut Eger
Senior Engineer
XING | LinkedIn
davidclarkee626
New Member
New Member
I’m also interested in how others are approaching this, especially with AutoPLANT Raceways being retired. I’m still learning the electrical side of Plant 3D, but it seems important to separate the 3D design/modeling from downstream electrical information. Even something as simple as keeping electrical data organized, like when checking a KESC duplicate bill, depends on having the right information available. I’d be interested to hear what workflow others are using with Revit or AutoCAD Electrical.
