AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
PLant 3D 3D drawing isoplanes issue
2 REPLIES 2
bbodorkos
62 Views, 2 Replies
Dear Users!
I have met an issue in P3D. I am trying to design a pipeline system, however I cannot change the isoplanes. I can click on the button and F5 also "works" but nothing happens. I can only draw in one plane.
What could be the source of this issue?
Thank you in advance!
BR
Barnabás
2 REPLIES 2
jflorita
in reply to: bbodorkos
while holding the pipe press Ctrl + right click to change the plane.
Michiel.Valcke
You can also use the Plane option when using the PIPEADD command to change your plane, you will see the Compass change planes while doing so.
Technology Administrators
