AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
PIPING COMPONENT PROPERTIES - ISO SYMBOL TYPE AND SKEY TROUBLE
1 REPLY 1
5138 Views, 1 Reply
Good evening mates,
I'm with a trouble about isometrics and i hope someone can helps me, basically when i generate the quickiso the flange doesn't appears on the drawing.
Follow the pictures of the spec editor:1.PNG
If you guys see, the field ISO SYMBOL and ISO SKEY was perfectly full filled.
To every ASME flange the isometrics generates correctly but to AME plastic pipes, no one works.
Thanks to the help!
1 REPLY 1
Slukerin
u need to make sybmbol like this - Screwed Flange. because skey FLSC works only with this one. or u can use another skey (symbol - Flange  Skey one of the following: FLSO, FOSO, FLSI, FLBL, FLSW, FLRC)
see the screenshot. uf u need more info about skey's and symbol  look at this file (De-mystifying AutoCAD Plant 3D Isometrics.pdf) page 16
Technology Administrators
AutoCAD Beta
