Pipeline Group Properties Do Not Display while using SLGROUPEDIT in P&ID
chaytonDTUYJ
chaytonDTUYJ
Community Visitor
Community Visitor
I have 4 properties defined in my pipeline group: System Designator-Unit-Service-Linenumber
The properties are defined in my Project Setup, but do not show up in my group settings on my P&ID. How do I add those properties to my pull down menu when using SLGROUPEDIT?
See attached images for reference
h_eger
@chaytonDTUYJ ,
regarding the "SLGROUPEDIT" command: where did you learn or read that custom properties can also be used with it?
https://help.autodesk.com/view/PLNT3D/2027/ENU/?guid=GUID-03B5ABF9-4740-41BA-A969-6102DB7822A3
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
md_arbaz_ansari
Hello @chaytonDTUYJ,
Test by adding the properties in the Line segment with Pipelinegroup.[properties].
