pipe line group tab EMPTY.
veronica.rosaGJXV3
Message 1 of 15
veronica.rosaGJXV3
I have made some diagrams with many lines. Now in the data manager, the Pipe Line segments tab is ok, but the Pipe line group tab is empty, without any registry. I have audited the project and it is still the same. Does anyone know how I can recove the line group registries?
Regards.
  • P&ID
Replies (14)
Message 2 of 15
Michiel.Valcke
Have you grouped your pipe line segments with line numbers? The pipe line group is determined by line number. All segments with the same number belong to the same group. If you have no numbers, you have no groups.
Message 3 of 15
veronica.rosaGJXV3
That's how it is. When I made the diagram, it had segments grouped into line groups. Now the groups have simply disappeared...
Message 4 of 15
h_eger
Dear @veronica.rosaGJXV3 ,
can you please show a picture of the data manager with the PipeLineGroup area?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 5 of 15
Michiel.Valcke
So if you use the select group command in your P&ID you are no longer selecting the group but individual segments?
If you use the SLREGROUP command and select a sline does the dialog show any linenumbers?
There is a known similar issue for singular lines that lose their group and get corrupted. AUDIT and regrouping them can fix this:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/For-some-slines-in...
Message 6 of 15
veronica.rosaGJXV3
You can see in the image 1, the line segments tab with 74 lines. In the image 2, the pipe line group empty. SLRGROUP doesn't works, the groups are in the list but the segments don't regroup.
Message 7 of 15
Michiel.Valcke
What does PLANTAUDIT and AUDITPROJECT say?
Have you tried the PnPLocalDataCachePurger.exe? (C:\Program Files\Autodesk\AutoCAD 20xx\PLNT3D)
Are you using an SQLite project or some form of collaboration/Vault/SQL Server project?
Message 8 of 15
h_eger
What is your TAG format for the PipeLine group?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 15
veronica.rosaGJXV3
Is a custom tag. Have 6 properties, and the segments lines acquire these properties from the group.
Message 10 of 15
veronica.rosaGJXV3
Audit say that no errors are. Is an SQLite project. This only pass in some diagrams. In my project we have 70 diagrams and all are ok except 2 or 3....
Message 11 of 15
Michiel.Valcke
Is the linenumber one of those 6 properties?
Message 12 of 15
h_eger
Ask for the documentation of your PipeLineGroup TAG format as shown in my post.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 13 of 15
veronica.rosaGJXV3
In the image 3, you can see de pipe line group tag format. In the image 4,  Pipe line segments with tag format where the properties are acquire from the group.
Message 14 of 15
h_eger
Unfortunately, there are serious errors in the structure of your PipeLineGroup TAG format for KKS.
Please consider the KKS guidelines in cooperation with AutoCAD Plant 3D.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 15 of 15
Michiel.Valcke
I have no idea about KKS, but I see no reason why the structure of the tag would cause the line numbers to dissappear.
I did see that your PipeLineGroup.Line Number reference is different in both tags, one is followed by the [NNN], the other is not. Which makes me think you are filling in the NNN (autonumber) formula when completing pipe segment tags, but not the actual line number of your pipeline group.
