Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD Plant 3D Forum
P&ID Tag valves related to equipment tag.
4 REPLIES 4
mpalomeque
210 Views, 4 Replies
Good afternoon everyone;
I would like to know if it is possible to relate the tag of an Equipment (for example a tank 910-201) and the valves of that equipment are 910-201-NNN.
And when copying the whole set, modify the tag of the tank and the associated valves are updated.
4 REPLIES 4
h_eger
in reply to: mpalomeque
@mpalomeque ,
this function is not integrated in Plant 3D by default.
There are APPs that include such a function that can be purchased.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
mpalomeque
Do you know any to recommend?
h_eger
Unfortunately not
Hartmut Eger
Senior Engineer
XING | LinkedIn
mpalomeque
in reply to: h_eger
I don't find it so strange. I always use it in my diagrams. Associating the valves and instruments to a specific tank. It's easier later, to be able to relate the valves in the field.
There are several things to improve in the program.
