P&ID line group tag error
bquataert
Message 1 of 17
bquataert
Trying to assign a tag to a branch line on a P&ID and get an error message stating "no two schematic line groups can have the same tag" Only problem is that this tag has not been assigned to the drawing or the project. Please see snip-its. Any direction is appreciated. Thank you.
Replies (16)
Message 2 of 17
rajendra.prajapat
@bquataert Please try after audit the database.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Message 3 of 17
h_eger
Dear @bquataert ,
Did Plant 3D crash before?
Running "AUDIT PROJECT" should solve this problem.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 4 of 17
bquataert
thank you for the reply. I ran audit project. Went into the file and got the same result. Other ideas?
Message 5 of 17
bquataert
The program did have an abrupt shutdown earlier in the week, not on the day in question (lost power), when I was in this file. Was / is running fine except for this issue.
Message 6 of 17
h_eger
can you show us a picture of your Line Group TAG format.
Not this from the line segment
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 17
bquataert
As requested
works with other digits.
Message 8 of 17
bquataert
wont let me place line number 0006 either but will let me place 0007
Message 9 of 17
Try the AUDIT DATABASE, instead of AUDIT PROJECT as Hartmut Eger suggested, if you have the AutoCAD Plant 3D 2022 version.
Message 10 of 17
bquataert
thank you for your reply.
I am using 2022
AUDIT DATABASE is not an option
Message 11 of 17
Oh it's because it is available only in collaborate projects, I didn't know it
So in this case I would try again Audit Project without anyone working at the time and run the commands AUDIT and PURGE in the drawing
Message 12 of 17
bquataert
thank you, tried the above to no avail
Message 13 of 17
daniel.klingspor
@bquataert
Try running the "PnPLocalDataCachePurger" in addition to doing the Project Audit.
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/screencast/Main/Details/6...
Also try removing this drawing from the project completely and create a new drawing.
Message 14 of 17
bquataert
Tried the former. The latter is a solution of the last resort.
I tried creating the line in a different drawing and go the same result
Message 15 of 17
daniel.klingspor
@bquataert
Sounds like you need to remove the drawing.  Creating a new drawing, without removing the old one, will not work.
Message 16 of 17
bquataert
so if I remove it, is it possible to re-insert it afterwards?
Message 17 of 17
daniel.klingspor
@bquataert
You could try doing that.  I've used that technique to fix corrupted drawings in the past.
But if it does not work you will need to purge it from the project.  Remove it, run the project audit, then run PnP purger.  Make sure no one else is in the project too.
To reduce redraw time, you could bring it in as an xref, from a separate project and trace it.  I wouldn't try to copy anything in, something happened to this drawing and you don't want to re-corrupt your new one.
I've had your situation happen but all of the steps previously suggested to you have worked  😐
