AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Orthos annotations questions?
5 REPLIES 5
popovUS9BY
318 Views, 5 Replies
Hello colleagues,
I have some questions regarding annotations:
1) Is there option pipe lines / spools to be displayed in isometric view ( key plan ) automatically?
Something like this:
2) How can I annotates sections in orthos?
3) Is there option description to be added to already custom created parts, so this description to appears automatically in BOM?
Regards
5 REPLIES 5
h_eger
in reply to: popovUS9BY
Dear @popovUS9BY ,
1. No
2. What do you mean by "section" cuts through your 3D design or areas?
You can annotate sections through your plant in the same way as you annotate plan views or isometric views. We cannot set ranges for the annotation.
3. no
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
m.bevers
1. Someone recently pointed me this Plant 3D plugin ( OrthoGen | AutoCAD Plant 3D | Autodesk App Store ). Haven't tried it myself yet, but it might be worth looking into
2. As @h_eger said
3. Not sure if I understand your question completely, but you can alter the default BOM list and add extra fields. But it requires quite some steps and I don't have time (nor the interest 😁) to write a full step-by-step manual here. Suggest you search and watch some tutorial videos on YouTube.
popovUS9BY
in reply to: h_eger
Thanks for reply.
Sections I mean the graphic symbols for positions of cut planes.
Where you cut from and viewing directions.
Regards
popovUS9BY
in reply to: m.bevers
1) What plug-in you mean?
3) Custom created parts do not have descriptions. When BOM is created, cells are empty.
Tuts on youtube always works, but when I try result is not the same 🙂
I do not use inches or latin letters, so everything is more interesting for me 🙂
Regards
m.bevers
Sorry @popovUS9BY, I forgot to add the link to that plugin 🙈
Technology Administrators
