AutoCAD Plant 3D Forum
Ortho viewcube grips missing
17 REPLIES 17
Message 1 of 18
bcweweng
2564 Views, 17 Replies
Just updated Autocad plant 3d 2020
Now when I try to create an ortho drawing the viewcube has no grips to stretch it
to the location I want the view to be from.
17 REPLIES 17
Message 2 of 18
bcweweng
in reply to: bcweweng
Can anyone please help me with this, I'm on a dead line for drawings.
I can't create any ortho's now.
Message 3 of 18
Hi BCarroll,
I cannot reproduce this behavior on my site. Have you already installed Update 2020.01? If the issue still exists with this issue: I will send you a separate email with an introduction how to send me the zipped project. So, I can look for it.
Best regards
Bernd
Bernd G.
Senior Product Support Specialist
Message 4 of 18
I have opened the project in 2019 and everything is fine in 2019.
Tried the repair of 2020 and still not working.
Message 5 of 18
bcweweng
My version is 2020.1 not 2020.01 as in your previous reply
Message 6 of 18
bcweweng
I have opened the project on another workstation and it works fine.
I think a reinstall of Autocad P3D 2020 is needed  😞
Message 7 of 18
Before doing a re-install, try that first (in this order):
  1. Close Plant
  2. Open Windows Explorer and delete the content of the temp-folder. Enter %TEMP% into the title bar of Windows Explorer to get to the right place. Ignore those files and folders which cannot be deleted. They are currently in use.
  3. Reset your Plant user profile: http://knowledge.autodesk.com/article/How-to-reset-AutoCAD-Plant-3D-user-profile
  4. Repair it via control panel
If a re-install is still needed, then do a clean uninstall before. See this article.
Please, let us know about the outcome.
Best regards
Bernd
Bernd G.
Message 8 of 18
in reply to: Bernd.Gerstenberger
Same for me following the 2020.01 upgrade...
Message 9 of 18
bcweweng
I have reinstalled Autocad plant3D 2020 but not updated to 2020.01.
All seems to be working fine now. I am reluctant to update to 2020.01
until I'm sure the problem is sorted.
Message 10 of 18
Hm, as mentioned before, I am not able to reproduce the behavior with the update installed. It might be caused by a corrupt installation. So, install the update and test then. Does this issue still happen. I don't think so. If yes, you can still uninstall it afterwards.
Bernd G.
Message 11 of 18
Got it. We have to differ between plain AutoCAD Update 2020.1 and Plant Update 2020.0.1. The issue is caused by the plain AutoCAD update 2020.1. So, currently the uninstall of this update will solve the issue.
The development team is already investigating here.
Bernd G.
Message 12 of 18
I was getting ready to re-install the whole mess.
Now, if you could identify why I can't save custom parts to spec catalog editor...
Message 13 of 18
chris
Are you still investigating?
Message 14 of 18
Bernd.Gerstenberger
in reply to: chris
Hi Chris,
please, can you start a new thread about your spec issue? Because this issue is completely about a different topic and a potential solution won't be found by other people when they are searching for it.
Thank you
Bernd
Bernd G.
Message 15 of 18
I was the one that commented about Spec challenge.
AND have started a post with the info.
With NO response.
I have installed Plant update 2020.1, hopefully it fixes.
Message 16 of 18
has this issue been solved. I have Autocad Plant 3d 2020 and suddenly have no Ortho grips. It worked fine before so not sure what has happened.
Message 17 of 18
bcweweng
After I uninstalled the AutoCAD update mine worked fine.
Message 18 of 18
Snomatic_Autocad
I have learned to NEVER install plain Autocad updates even if the update manager suggests.
ONLY do the Plant updates.
