AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Ortho BOM table Style
8 REPLIES 8
Message 1 of 9
josh_cook
698 Views, 8 Replies
I Have changed the colum/Rom height/Widths in the table editor but when i sect update BOM the table reverts back to an ugly default size.
How do i make the dimensions of my BOM table stick?
8 REPLIES 8
Message 2 of 9
in reply to: josh_cook
Delete the table in the ortho. Open the ortho.dwt file you modified and
copy to clipboard and paste into drawing.
Run the BOM command, not update. This should provide you with a new BOM
with table changes.
Message 3 of 9
josh_cook
I copied the table from the template, pasted into drawing, create bill of materials, selected view.
Thats not working for me, the table columns change size still?
Was hoping for a simple answer? cant find whats driving the table size
Message 4 of 9
I've had that exact problem before. Try purging after you delete the bom
table save the ortho. Then paste the newly modified table from the
ortho.dwt. Hope it works.
Message 5 of 9
josh_cook
Here is a video of what i am doing, I also tried purge but still no luck? is there a special plant purge?
Message 6 of 9
josh_cook
Also created a new drawing with the BOM table setup how i would like it in the template.
When i first generate BOM it works as i would like it but then if i ever need to update it, the size changes still
Message 7 of 9
That's correct, a bug they haven't yet worked out. My work around was to
delete the BOM table, paste the new one, then choose create BOM, not update.
Message 8 of 9
josh_cook
Thanks Dave, Ill just have to do that until it is fixed. Its not too much work, just was annoying me.
Message 9 of 9
I have commented on the existing idea board post for this topic.  I have also tagged everyone who reported having this issue.  With enough traction, hopefully this problem will be fixed.
Anyone who has the same issue as what's discussed in this post, please vote in this idea board post so we can stop having to use workarounds!
