- Mute
- Permalink
- Report
Hi there
As i'm new to Plant 3D i feel like i miss something fundamental/simple, but can't get behind it....
When exporting catalogue data to excel, every floating point number, which could possibly interpreted as date, is changed when opened with excel. First this looked like the usual dot vs comma problem to me, but it isn't. What i have tried to verify:
- Changed excel settings to not overtake windows settings regarding floationg point number writing.
- Fully deactivated excels data translation feature.
- Made export tests with several settings: Changed windows setting from dot (standard here in switzerland) to comma, and then back. Also changed these setting within excel corresponding (or explicitly not). Restarted the computer between all export tests to be sure everthing was overtaken.
The only recognizable result was that when all was set to dot, numers were all displayes with dots, but the problematic cells (the ones intrepretable as dates. i.e 2.11) always show dates. This must be happened during export, since we have to fill in some values with comma delimiter (se below):
To be sure, that the problematic conversion takes place during export from Spec Editor, i also used the power-query editor to have some insight to the exported data befor the excel file opens. Indeed, the data change is already there before opening the file.
Now, if we could fill in the values with the dot delimiter in Spec Editor everything would be fine, but only the comma delimiter is accepted, dot is always ignored. I can't find any setting where i could change this. What do i miss? Is there any config file, where i can change the basic settings for Spec Editor/Plant 3D itself? Is there any export settings file, where i can change the type of specific columns?
Or even more basic: Can i change the type of a standard property catalogue-part? Where can i find this?
Thanks in advance for your reply.
Greetings, Dominik
