Offset piping annotation tolerance
DGRL
DGRL
Dear forum
Where can i change the Offset piping annotation tolerance?
When I route a pipe with an offset lower then 2 degrees the triangle is not shown on isometric.
Last project we had a pipe with a very small offset but over an distance of 50 meters it was 175 mm off.
This was not shown on isometric resulting in wrong pipework.
In project setup i could not locate tolerance settings for the angle
Does anyone knows how to change this ?
Regards
If this was of any help please kudo and/or Accept as Solution
Kind Regards
DGRL
Tollerance can be set in isoconfig.
OOTB is 1.5 degrees
Kind Regards
