AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Nozzle tag annotation in ortho drawings
5 REPLIES 5
pratikk20990
1120 Views, 5 Replies
AutoCAD Plant 3D has given inbuilt option to tag nozzles in ortho drawings but I cannot find a way to place these nozzle tags as everytime I select the nozzle, the command window displays "Annotation requires a Nozzle object".
The problem is that ortho drawings produce a single equipment block with all the nozzles forming part of the equipment block and as such there is no option to select nozzles separately.
I have noticed others in the forum experiencing same problem but no one has provided any solution so far.
Please provide some solution to tag nozzles in ortho drawings.
Tags (1)
5 REPLIES 5
pratikk20990
in reply to: pratikk20990
Can anyone provide some solution to this issue?
Yes. It is a work around. Listen up:
Create a custom nozzle ID property for equipment, at that level (node).
Assign the nozzle number to that property in the model.
Create an annotation calling on the equipment property and use that
annotation. You can xref the model into the ortho with a offset vport. Done
deal.
pratikk20990
Hi, Thanks for providing some solution.
However, I am not able to clearly understand this statement - "Create a custom nozzle ID property for equipment, at that level (node)."
Can you please elaborate on this?
pratikk20990
@Anonymous can you please elaborate and respond to my query above. Thanks.
mikael.santospj
HI, any progress on this query ?
I did this, it worked but Plant only show the tag of one nozzle. When I try for the other one, it keeps me showing the tag of the first nozzle.
