AutoCAD Plant 3D Forum
NOT CREATE CUSTOM SIPHON WITH PYTHON
5 REPLIES 5
traiduong014969
340 Views, 5 Replies
Hi all,
I'm trying create a custom siphon. There are shape siphons I tested with "(TESTACPSCRIPT "siphon name")". However there a shape siphon not working. For detail, It has a name is "CPMDD".
This is link to this file : C:\Program Files\Autodesk\AutoCAD 2023\PLNT3D\ContentScripts\metadata\varmain\miscellaneoussub\cpmdsub\cpmddsub
I want to create this shape. but when I test, it not working.
Someone can help me.
Thank you,
Have a good day!
5 REPLIES 5
I think u should input right dimension. If dimension is right but can not creat a shape. U should change some dimension and check one by one dimension. I think the parametric from Autodesk have some mistake, Take care about it.
Yep, I try with some change dimensions, however, It not working.
This is an example of parametric.
o1a = CPMDD(s, D = 40, L = 2000 , H1 = 1000, R2 = 300, E = 80, OF = -1)
@traiduong014969 its generating with default parameter.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
@traiduong014969, It seems to be an issue in 2022 and 2023 after the Python 3 conversion. Testing in 2021 works fine, but both 2022 and 2023 are failing.
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
yep, I tested in P3D 2021. It working, but with the 2023 version, It not working
